Old 08-23-2014, 12:41 PM
blykins blykins is offline
This one is not. It's not a high rpm engine, nor will it be a high hp engine, relatively speaking.
On a $250 crankshaft, having to add $100-200 worth of metal just isn't cost effective.
Spent another 30 minutes on the rocker arm geometry, just wasn't happy with it.
Went through a couple more iterations with the pushrod length checker and got it to where I didn't lose any valve lift.
FWIW, a 6.225" pushrod lost .005" worth of lift at the retainer. A 6.300" pushrod didn't lose any, and the pattern was good, just a little past center on the valve tip.
Good retainer to rocker arm clearance. Check.
Good pushrod to rocker arm clearance. Check.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
