Originally Posted by Cobra #3170
Chas,
My Dailey dry sump pump pulls 13" of vacuum when the engine is running so it does not leak. The dry sump tank is mounted in the trunk so it is higher than the pan and most of the oil drains back to the pan over time when not running. This puts more pressure on the rear main seal since it is submerged in oil.
Great solution that kills two birds; great oiling and little crankcase pressure.
My last hoped-for project was going to be a Moroso vacuum pump but I wasn't smart enough to figure it; space for the pump, drive system, etc.
Always wanted vacuum for ring seal and all the other benefits.
Dry sump would have been nice too but again, logistics weren't good. Plus I didn't really need it at only 550HP.
