Flywheel, pressure plate, clutch, bellhousing, hydraulic clutch slave, intake, and reverse rotation water pump are now installed.
Unfortunately, concept 1 sent me the wrong pulley system, so it all has to be removed and returned. They are sending me the correct system, but this one will be polished instead of black anodized.
Checking the bellhousing alignment. Everything checked out ok.
Aluminum TKO bellhousing, clutch fork, and clutch slave kit from Modern Driveline.
Their clutch slave kit was very easy to install.
Wrong pulley system
