I called Tremec and they gave me the name of a guy in Texas who has the plugs for the transmission. I made a wire harness from the transmission plug to the plug on the harness next to the rear diff. After doing that I found a wire in the harness close to the tranny in the harness running down the frame on the pass side. I think it is for a tranny hook up. Looks to be the same color code as the one coming to the rear end. Check it out. The plug for the transmission has two wires and it does not make a difference as to how you wire it up according to Tremec.
