Sorry if this is not right on point. If you have a carbureted engine, and are switching from mechanical, one down side is if the floats stick you can flood one or more cylinders and then if you go to start it you can have a hydroloc situation, and you can break pistons, rods and many other valuable parts. This happened to a friends Shelby aluminum 427 engine I helped him build last year. Big $ loss.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Reason: spelling
