Originally Posted by davids2toys
I think it would make a big difference, I would do it
Yes, I have the Hurst but don't know what you mean by ERA lever?.
My shift lever was fabricated by ERA. To make sure John sent me a tracing of a lever in stock and it matched mine perfectly. I think I will go ahead and raise the mount plate up the rest of the way. A 1/4 inch or so might make a small difference. So far with the new rubber boot I'm not having any problems. It seems to be staying locked solidly in gear when in 3rd.
Originally Posted by rub35
This is mine in third gear. Quite a difference. I've seen several that look like Dan's and several that look like mine. Why so different? Is it the trans or the shifter set up?
Attachment 24323
That's a puzzle to me also (I assume you have a toploader and Hurst shifter). I'm wondering if there might be a couple different mount plates used over time that mount the shifter unit at different heights.
![Confused](images/smilies/confused.gif)
I also think I remember (hope it's not a figment of my imagination) that somewhere along the line, ERA raised their transmission tunnel height a little to better fit 5 and 6 speed transmission with top mount shifters. But, our cars all seem to be fairly recent models so I would thnk the transmission tunnels would be the same.
