I am a fan of independent front and rear suspension so if you are going to fab a chassis I would highly recomend using XJ6 Jaguar front and rear suspension I was building a Rod and not only did I use the front & rear suspension but I also used the brake booster & master cylinder(which can be seperated only leaving the master cylinder on the firewall, I also used the brake pedal and powersteering the engineer was all for this idea as it has passed ADR's allready so no brake testing was required buying these parts individually can add up so look into purchasing a whole car and wrecking it, I did and ratted everything I need and sold off the rest, the funny part is I made more on the parts than I paid for the car, bonus
Happy to be living past my "USE BY DATE"
