eedeutsch,
After you got yours tuned do you happen to remember the timing @ idle (~12 degrees???) and then the total advance (~32-36 degrees??) Be good to have a good place to start.
Did the springs get changed at all in the distributor. If they are double silver (tightest) then perhaps adding a lighter spring would improve the curve for these Iconic 427 engines?
Thanks
