Old 04-13-2002, 01:38 PM
Joe Prochazka Joe Prochazka is offline
Cobra Make, Engine: Unique 427SC-Junkyard 390 with a few aluminum parts-toploader
Default remote oil filter adapter
Can anyone tell me a sure fire way to tell the direction of oil flow on an oil filter adapter on a FE?
I am using an adapter made by TD Performance (P/N TD-1015) and it seems to me that the oil discharge and the oil pressure fitting port should be common. This is the adapter that bolts to the block in the place of the stock filter and has 2 large holes for the filter lines and a small hole for the pressure sender. I think that it bolts up with the small hole forward but I am not sure about the oil discharge and intake lines. I am installing a remote oil filter.
There are no arrows that show flow direction. I tried a search but came up with nada.
Thanks in advance for any help.
