It kind of depends on where it is welded. It was easier for me to just cut out the shaft and buy 2 joints and the Double-D bar and replace the whole thing. If one joint is bad, the others may not be far behind.
I found Sweet Mfg. in Michigan makes all the various joints and they are really nice. The diameter is a lot smaller than Lokar or some of the other brands also.
Do you have a support bearing?
