Originally Posted by LMH
Is the hood hitting the tank itself or the cap?
Some careful measurements this morning, peering through the sidevent holes and its actually the front edge of the cap hitting the hood/bonnet underside. I have just laid the hood gently on top of the hood aperture, and its proud at the front by about 8mm - the lever effect of the pivot that that the front edge of the cap produces makes it worse than it is, I think if the cap was just a few mm lower, then all would be fine.
Mick, thanks for the advice.
Need to make some more measurements. As its so close, another solution would be to cut a hole in the underside skin, to act like a Gurney bubble, kinda in reverse, as I think the 2 grp bonnet skin means its about 2cm thick where it touches the expansion tank cap.
