Old 09-07-2014, 07:09 PM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
I worked on one skiboat with water problems. The tank vent was outside of the hull near the driver high above the water line. But if you did a tight turn, the vent was under water, facing forward. Duh!!
I've seen several vent on top of the rear deck, then when people get onto the boat after skiing it would suck into the vents.
Obviously you cant have the vent inside the boat.
Most fuel injection fuel filters would swell if water goes through them, blocking the filter. 200Ml of mentholated spirits would dissolve any water in the tank.
JD
