Old 09-08-2014, 01:02 PM
patrickt patrickt is offline
Originally Posted by rodneym View Post
Pat,
Between you your LED brakelights and now 'flasher show', you're just one small step away from...
Light Show - Club Cobra Photo Gallery
They'll make your pipes look like they're glowin'.
Funny you should mention that... because, when the relay that controls the brake/turn lights is fed 12 volts to both of its turn signal feeds, at the same time, it politely back feeds 12 volts up through the brake light input wire. Sooooo, the result is that my nifty little third brake light also flashes when the switch is on. Thank you very much.
