As others have said, the alloy case box is the weak one.
You want the steal cased P50 if you have many upgrades on engine.
If a fairly stock 302 then the W50 should also suffice.
From memory a steel case and alloy case are both physically same dimensions outside, so a swap in your case should be faily simple.
I have a steal case I am using on another project, If need be I can put a tape measure over it to see if dimensions are the same.
Cruising in 5th
