DWRAT,
Flushing brake and clutch fluids is not a particularly difficult task, but if you've never done it before, I think the advice given here by others to take it to a good mechanic would be money well spent. You could watch how it's done and decide if you want to tackle that job the next time it needs it.
Originally Posted by Dwight
Using DOT 5 in a DOT 3 or DOT 4 system without proper flushing will cause damage to the seals and cause brake failure.[citation needed] DOT 5 brake fluid is not compatible with anti-lock brake systems. DOT 5 brake fluid absorbs a small amount of air requiring care when bleeding the system of air.[citation needed]
I would be very cautious about using DOT 5 fluid in a system designed for DOT 3 or 4. As the quote posted by Dwight above states, the systems need to be THOROUGHLY flushed of all previous fluids and even then, if the seals, o-rings, etc. were not designed for DOT 5, you may really screw up your brake and clutch hydraulics.
Just my two cents.
Ted
