Old 09-11-2014, 07:20 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
X2 on the caution about mixing DOT 3/4 and DOT 5. They aren't compatible.
There have been a number of threads about it here on the forum.
The use of a compressor driven unit to pull the old fluid out or a pressure unit to push old fluid out is definitely a plus. If you go with a pressure unit keep the pressure low. I use 5 psi with my Gunson unit and can do the whole operation by myself in about 20 minutes.
DonC
