  #23 (permalink)
Old 09-12-2014, 11:16 AM
MAStuart MAStuart is offline
RSK289 I have a few comments and questions. Some of your answers might help others, myself. and you.
1 Engine and trans angle should equal pinion angle. The angle should be going the same direction (they should be parallel to one another). That would you have to do to get the angles the same. Raise the trans more or lower it?
2 Did they ever put Top loaders in leaf spring cars from the factory?
3 If they did install some top loader trans from the factory what shifter tower and what linkage did they use. (What model car was it taken from?)
4 I think you said that when the Tbird rubber was installed it was about level with the top of the frame rail. This means the rubber mount is about 1 inch thick and the plate that it wraps around is about 1 inch down from the top of the frame rail. Is this correct?
Mark
