  #24 (permalink)
Old 09-12-2014, 11:42 AM
MAStuart MAStuart is offline
RSK289 is any chance that you could post some pictures of your trans mount and cross member and also your engine mount ( the brackets that are welded to your frame that the rubber mounts bolt to.)
The reason I am asking is because I am scratch building a Daytona coupe. The coupe the engine was lowered 1 inch so my engine mount brackets should look shorter than yours. I think the plans that I am using has some problems. I think my engine mount brackets are right but my trans mount bracket is in the roadster position and not lowered as would be required to get the engine and trans to the right angle. IF this is correct I will have to dent the cross member at the transmission for clearance of the shift linkage and the big angled support fin on the bottom of a t10 trans. If I raise the engine at the front mounts 1 inch my drive line angle is correct and the linkage will clear the trans cross tube.
Mark
