Originally Posted by lippy
I went ahead and finished this last night. Thanks Patrick. But I did do a few things differently. I didn't wire the dash lights to flash. I don't want any of those hard to reach small bulbs to fail more quickly. I used AWG 10 wire and soldered most of the connections under the dash. I also mounted a rocker switch hidden under the dash on a small aluminum bracket I made.
Nice. Are you running the super bright LED rear lights? (see:
LED Upgrade to Rear Rectangular Lights ) The total amperage draw on my four way flasher circuit with normal 1157 bulbs up front, the LED lights in the rear, the dash light wired in to the circuit, and an electronic flasher, is just a hair under five amps (and that includes my third LED brake light as well).
