Yes, the MSD requires 12.5 volts to fire..and fire volts are supplied by the alternator, not the battery. I run MSD (the old Ford SVO stand alone ignition) and I know that NO battery will hold 12.5 volts under a load test! It's optimum charge is 12.75-12.5 volts, which means that it would have no voltage drop under load! A battery will regularly drop below 11 volts with a severe draw, and still start a car! I really believe that the problem presented here is either fuel or ignition related. I would lean toward a fuel problem as the first thing to check, just because it's the easiest!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
