Thread: Tire pressure
Old 09-23-2014, 05:54 AM
strictlypersonl strictlypersonl is offline
I hadn't noticed that the recommended tire pressures are different in the 427 manual and the FIA manual. The correct starting pressures for both cars are 28 psi front, 26 psi rear when using 7.5" and 9.5" wide wheels. Depending on the tires, I would probably end up with somewhat less pressure after road testing.
