Thread: Coolant leak
Old 09-24-2014, 04:22 AM
jeffgrice jeffgrice is offline
Cobra Make, Engine: SPF Coupe #136, 427SR FI
Originally Posted by SwiftDB4 View Post
Any way for intake manifold to leak and only run to outside of block/head interface at front cylinder? Only coolant leaking, no oil. Water pump OK.
Very possibly.
I had spotty coolant on the block sides, near the water pump and at the back of the block.
IT WAS AN INTAKE GASKET. Each of the ports were deteriorated due to the intake not torqued properly.
R&R the intake gaskets with Roush spec'd metal lined gaskets and all set.
Jeff
