Old 09-25-2014, 11:09 AM
jimbo01 jimbo01 is offline
Cobra Make, Engine: Backdraft #832
Kobura
I am not sure what you mean by "stock" gauges. They normally would be Autometer, VDO, or Smith's. Depending on what Backdraft installed in the build this should be the case. If the speedo and tach are Autometer then most likely the others are the same. It's possible that your gauges do not need the additional ground that the VDO gauges need. Read your gauge instillation instructions for this info. You can find this on line by checking the manufacturers instructions.
