I think you can change the location of reverse (forward or back) by altering the attaching point of the reverse linkage rod to either above or below centerline of the connector on the shift fork. It will require different connector link since they are "keyed", or as I did on my T10 cut the existing connector link and reweld it, it will also require reworking 1 or more of the shift rods or aquiring one from another application that had reverse in the desired location. In the photo below the rear lever is pulled rearward for Reverse with the Shift lever moved forward.
You can also with great success make your own shift rods by using high quality male rod ends and either mild steel or stainless tubing.
[IMG]
[/IMG]
