Originally Posted by bliss
I have an older ERA....
Lights OFF: I'm not getting a 'flash' from the right tail light (right turn signal) (left is fine).
Lights ON: both tail lights do come on, but no 'flash' from the right or left tail light.
The front turn signals work fine - light off and on.
_____
Does this sound like strictly a wiring issue or are there parts to be checked, also?
Any input will be appreciated.
The first thing I would do is switch the bulbs, both up front and in the rear. See if any changes occur. If not, then you know it's in the circuitry and you'll just have to work your way back up. There's really not much there in the turn signal circuitry. It's pretty easy to diagnose. But switch the bulbs and report back.
