Old 09-28-2014, 06:02 AM
Default 3 guys I can think of
ERANJ Try Barry Robinick, Jay Brown on the FE forumn, Brent Bylkins. I would also check e-bay, craigs list, FE forumn, FE power forum. May have luck there. Rick L. Ps what is the matter with the manifold you have?? If aluminum it can be repaired. If rotten or leaking at the coolant ends, Use J-B welding 2 part epoxy. Tubes in the ports with vacuum leaks same thing. Call me 732-254-3536
