  #22 (permalink)
Old 09-29-2014, 06:59 AM
jimbo01 jimbo01 is offline
Cobra Make, Engine: Backdraft #832
Spent some time Saturday correcting the ground problem on two gauges. Mounted a ground bus bar and installed separate grounds on the gas gauge and volt meter. Found the volt meter is giving an incorrect reading. The voltage at the gauge is 12.5 volts and the gauge shows less than 12v. Not sure if the problem with the water temp gauge is solved. Know more when I start it up again.
