Not sure why you would need shims. Check the extension of the starter gear, measured from the flange of the starter. Make sure it engages at least 1/3 (preferably 1/2) of the thickness of the flywheel. It should. Then just clock the motor on the starter so it is in a good position and bolt it on.
