Old 04-14-2002, 07:59 PM
ERA535's Avatar
ERA535 ERA535 is offline
BLACKJACK-
Here is a shot in the dark but you never know...
I see where you said that the ignition key gets hot sometimes, then you said that the fuel guages are reading incorrectly and the water temp guage is indicating a temp that is higher then it should.
Is there a possibility that there is a ground problem or some other kind of electrical issue in the wiring in your dash?
I think you should make sure that the temperatures that you are getting are real - maybe the guage is indicating too high.
Good luck.
Pat
