10-07-2014, 08:02 AM
KY
You will need a custom grind for an FE if you want a cam that works well with the FE lifters and valvetrain.
Don't need a Torrington bearing for either thrust or cam....traditional cam bearings work great and a regular Ford Racing timing set with factory thrust plate is all I use.
