Originally Posted by Karl Bebout
Rati-Dan,
I've got a four post, drive on lift you are welcome to, if you dare to come out to "God's Country".
We installed a front bar on Mesa Mike's car a couple years ago and it required welding a couple tabs onto the frame. His car is a FFR and I don't know if your SPF requires that or not. Even with the welding, and triple measuring, it still took only a couple hours or so. If you are a welder, you can use my MIG or I'd be glad to do it for you. 480-320-8296
Thanks for the offer Karl.
I ended up getting 4 ramps and started my sway bar installs last night.
Should be done tonight if I crawl under there again.
