Tim7139 Tim some of the guys run the large fuel filters that looks like an
oil filter. I don't allow my fuel to stay long in fuel tank. I run system dry for winter and leave 5 gallons in it with stablizer. Have not had to clean injectors in 15 years. Pressure 48 psi and fires up on 2nd rotation.
Mild corrision in distributor. GM sells die electric grease in a little 2.0 oz white container. Blow out inside distributor. NO cleaners. Want to add a very thin covering around module and plate.Works as a heat sink to help cool module too. The good stuff is non conductive. The last couple of years the quality of metal has dropped and connectors are failing at a high rate. They can't take the ampage like the old ones. The littlest bit of corrosion and a problem happens. I will get you the # if you want to get some from GM. There are different grades of this stuff. It's not the same as brake pad grease. That's a die silicone grease. Couple of wing nuts tryed this and had problems.
. Any way later. Rick
