Mark, I would have them restrict the
oil to the top end through the cylinder heads and not the block. If you end up changing your mind on a cam, or lifter, or application, it's easier to just add/remove a restrictor through the head feed than it is to pull the heads and make changes to the deck of the block.
At .060" you're probably ok, but if they have the ability to sonic test, I would.
