Old 10-15-2014, 09:35 AM
petercory petercory is offline
Default New Smiths Cobra Gauges
NEW FROM NISONGER INSTRUMENTS
As you probably know, up until now, if someone building a Cobra Replica also wanted to replicate the look of the original Cobra Dash, they were forced to install Smiths mechanical Water Temp., Oil Temp. and Oil Pressure gauges. The potential of damaging the capillary tubes or sensing probes during installation or while servicing the engine at a later date combined with the need to install a pressure line between the engine and Oil Press Gauge resulted in many owners installing electric gauges that really don’t look correct. Virtually all electric gauges currently on the market have a 70° “pointer sweep”.
In an effort to combine the best of all worlds, Nisonger has been working with Smiths for several years on the development of a line of ELECTRIC 270° pointer sweep electric Water Tem, Oil Temp, and Oil Pressure Gauges; the results of those efforts are the new series of 427 Cobra 270° sweep electric gauges.
Additionally, an original style Electric 270° 10 PSI Fuel Pressure Gauge for Carbureted Engines and a 100 PSI model for modern day Injected engines is also available.
These 427 Cobra Electric gauges are identical in appearance to the original mechanical gauges in every respect and will be available for shipment in late November ONLY from “The Source”:
Nisonger Instruments
225 Hoyt Ave.
Mamaroneck, NY 10543
(914) 381-3600
info@nisonger.com
Nisonger Instruments :: the exclusive Smiths U.S. Warranty & Service Center since 1949
