I had the same problem but was able to get it loose with a strap wrench. I then replaced the filter with a canton remote filter system. Got most of the parts I needed from Summit racing. It's not an easy job but now the filter is located under the radiator fill. If you don't know how to put ends on AN hose get someone who does do it. At least now the filter is easy to access but you must use the NAPA or Wicks filter. All others will leak. I tried several.
