Old 10-21-2014, 12:17 PM
crenbbf's Avatar
crenbbf crenbbf is offline
Default Bolting up a Quicktime to a Toploader
Hi All
I could do with a bit of advice regarding which type of bolts to use.
My Toploader did not have any bolts attached and there are none with the bell.
The bell does have the bell to engine bolts.
The bell is a 6057 so not SFI but looking at the kits the only visible difference is the block plate to bell housing bolts is this the case?
Which bolts do you recommend for both the bell to block plate and also bell to trans ?
cheers Kiel
Crendon 427s/c No68
434FE
