  #214 (permalink)
Old 10-25-2014, 06:43 PM
hisss snake hisss snake is offline
Cobra Make, Engine: Classic Roadsters II, Ford
Default 572 Cobra
I hope this is where I sign in for Ford big block powered cobra . I built a 572 stroker from a premier eliminator block with 4.5 " bore and 4.5" stroke . Forged crank , h-beam rods , diamond pistons , canton pan , crower cam sitting on roller brgs. , crower solid roller lifters , danny bee belt drive , trick flow a460 18 stud heads , comp cams stainless roller rockers , trick flow stud girdle ,trick flow tall intake topped of with an sv-1 carb. fired it up last january sounds good . Have a mcleod street twin out back with quicktime bellhousing and before I get the car on the road I just pulled my toploader and will be replacing with t-56 magnum .
