Old 10-27-2014, 01:48 PM
505stang's Avatar
505stang 505stang is offline
Cobra Make, Engine: B&B 351C
So sorry for your troubles - I looked at your photos in your photo gallery and that is a spectactular paint job. But your OK.
That is odd on the grade 8 bolt - I suspect that either the bolt was a Chinese grade 8 or the bolt gets a lot of bending stress. Grade 8 bolts are a little more brittle that Grade 5 bolts although superior in tension and straight shear.
Good luck with the repairs.
Thanks for the complement on the paint, as for the bolt, after looking under the car it looks like a bracket fatigued around the bolt hole causing excessive play then the bolt failed because of the slack. Car is back together by Sunday night, all i have left is fix glass and paint.
