If you fool around with Ride Height, it should be measured with the driver IN the seat or...use masonry blocks which weigh 40 lbs. each and use the appropriate number of blocks placed on the floorboard and drivers seat to measure! In addition, the sway bars should be disconnected when setting height to eliminate any preload.
A 200 plus lb. driver equals about 10% of the total B/D weight so it's important.
