I did not realize you answered much of the above by embedding in an earlier post - thanks.
Fantastic you will wind tunnel. You are taking some risk.
Curious of your projected ground clearance with respect to your bottom aero.
Will the suspension geometry accommodate or would you possibly run a dropped bottom to get the right throat? What angle are you running your diffuser at?
Did you keep the trunk?
How will you handle the side pipes?
x-chr
