I'm inspired mostly by SKINNEDR's post to offer these comments as food for thought.
Any time a part fails you need to discover the underlying reason and fix that too. Occasionally you will find a failed part that was simply not well constructed or not intended to take the forces applied to it; but if you replace it with one just like it, it will likely fail too. Of course replacing the failed part with a stronger one may lead to you discovering the next weakest link in the chain of parts that is a car.
For those who may not know, Grade 8 is not always better than Grade 5 for all applications. In simple terms, as forces build on a bolt, a Grade 5 may bend and deform before a Grade 8. But as the force build more, the Grade 8 may snap while the Grade 5 only deforms more. The question of which is better depends on the application. In some cases its better to have a bent bolt than risk having a snapped one.
Lastly, I used to take my car to the track, so I have seen lots of failed parts and systems. I look at each failure as an opportunity to make the car better than before. My goal is to fix each failure such that it will not happen again.
Tommy
Previously owned EM Cobra
