Old 11-01-2014, 06:25 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Helped a friend with an SPF put his top on for the first time and, even without instructions, it wasn't hard to do. SPF does a good job with their tops and side curtains and the fit is pretty good.
I would advise doing it in the garage a couple of times so you get used to any quirks with your unit under good conditions. After that it should be a breeze.
Practice getting in and out over the pipes several times once the top is on for the first time. You might have to do some creative body folding but you'll get used to it.
The cars do have a different look with the top on. From some angles it looks even meaner.
DonC
