Originally Posted by Car Nut
They make extension rings (also called plaster rings) that make up for the thickness of the wallboard. You could save the expense of an electrician and use the money for ammo.
Yep, go to Home Depot, they should be under $1 per outlet.........
THOUGHT FOR THE DAY: There is more money being spent on breast implants and Viagra than on Alzheimer's research. This means that by 2030, there should be a large elderly population with perky boobs and huge erections and absolutely no recollection of what to do with them.
