Hi Modena.
10MM is ridiculously thick. You can easily reduce that down to 1/8" or 3MM more than safely. Does your body have core reinforcement under the cowl?
You can also use T nuts. They come in various sizes and depths.
You will need to bore the backside of the hole a little larger, but
not too much surgery.
Good Luck,
Mike.
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
