The slow-blow type gives you a little leeway, especially with motors that draw high starting current. I normally use slow-blow in all the firewall fuses. On the other hand, I use fast-blow for the two fuses (under the steering column) between the trailer relay and the rear tail lights. That's to avoid damaging the relay should you accidentally short out the wire.
