Originally Posted by Tim7139
Outside??? WTF?
I mean like an outside garage that will go down to below zero. Really, the only things you absolutely have to guard against are the temperatures dropping below your
antifreeze level, vermin, gooing up your gas, and surface rust from the temperatures going up and down around your condensation points. Even on a "kind of heated" inside garage, this is what I use:
CarBag - Protective Jackets for Storing Your Car or Motorcycle. Made in the USA. I'm actually on my second one. One year I had a brake fluid leak that dumped a sizable amount of brake fluid in to the bottom of the bag, so, obviously, it couldn't even be reused. Yep, that was a pissssser....
Antifreeze, Stabil, and a Car Bag with desiccant and your car will come out exactly the way she went in.
