Old 11-09-2014, 07:51 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by kevins2 View Post
Experiencing a problem and looking for suggestions as to what it might be:
- Problem started with a slight hesitation when first stepping on gas from a stop. Occassionally, a loud backfire as it is getting underway - always from driver's side.
- Problem got progressively worse and car won't idle. Smooths out at about 1500 RPMs. Backfire from driver's side more frequent. While underway, car runs just fine.
Setup: 427 side-oiler, Edelbrock Performer RPM heads and intake, Holley carb with vacuum secondaries, MSD ignition, coil and distributor.
Thanks for any help.
Kevin
Simpler ideas that take 5 minutes to check:
Did the bolts that hold the carb to the intake loosen?
Is there a fuel drip from the carb to the intake (exterior staining)?
Did you have a backfire through the carb that could have blown out the power valve?
Which MSD ignition set up do you have? (be specific)
MSD Box?
MSD Distributor?
MSD Coil?
Bill S.
PS: Backfire on deceleration, if so, tighten your header bolts.
