Old 11-12-2014, 10:06 PM
GT350Mike's Avatar
GT350Mike GT350Mike is offline
Cobra Make, Engine: CSX6363
When I read your post earlier from my cell, I didn't realize how much info was given in the CAD drawing, especially the specs on the square pin. I think the lube I have from the bike shop will suffice but if it fails, I'll either go with the motorcycle lube of the Dri-Slide.
So far, I've checked the cable rotation with and without the adapter and appears to work fine when I spin the tires. I also tested the adapter on the speedo with the drill and again, it checked out okay. The only thing I haven't done (yet) is disconnect the cable assembly from the transmission to verify if cable feels like its rotating freely.....I save that test for last. After reading through all of the info, I honestly think it's a clearance issue with the cable end or the square pin. Hopefully I'll be able to put scratch this off my to-do list Saturday. Thanks everyone for the info!
