Old 04-16-2002, 11:54 AM
RACER X #99's Avatar
RACER X #99 RACER X #99 is offline
Default Could be the block???
Denny,
I once had a SO 427 that would not stop leaking oil, finally got under the car with the engine running at a good rpm and then discovered oil leaking right thru the side of the porous block. Drilled a hole thru and tapped for a 1/8 pipe plug. No more leaks.
McX
