Thanks guys for the information.
The frame is set up to accept a factory live axle from a Mustang. This means that all components bolt to the frame as they would with a stock Mustang. The axle was mounted to the frame in that picture. The bolts were there holding it in but it was not torqued down.
I will probably go with new control arms, springs, and shocks.
Joyridin' - you bring up a good point.. I am sure my dad thought of this when he decided to go with a 94-95 setup. What i will need to do is get the rims installed on the axle and measure and compare with the body. I had no idea there would be an issue with this...
Clubcobra member Larry Ruppert 1951-2014
